Koni str.t
Big Eldorado
Protege es 2002
So i know these are new for the 3's but has anyone tried the KONI STR.T shocks out? I just want a simple set-up thats better than the "float" through corners i get with the stock shocks. I was thinking of the koni sports with H&R springs but i dont want adjustable shocks, not interested in all that hassel. Just need to stick better and sit lower...
Thoughts????
(dance)
The STR.T are absolutely not recommended if you want to lower your car. Koni explicitly states this about these shocks as it doesn't allow them to function properly.
If I were you I wouldn't avoid Sports because they are adjustable. I have Konis on right now with stock springs and the improvement over the crappy OEM shocks was awesome. I have no plans of adjusting them ever. :D
FWIW, I have H&R springs that I'm going to put on in the Spring with the Konis. Another thing you might want to consider is trimming the bump stops or replacing them when you do upgrade to whatever you choose.
