irishkev90
- 1998 Mazda Protege LX
Posted this on clubprotege, but thought it might be helpful here as well.
Did some research and compared the Kia axles to Mazda axles. For the record, I used a 1996 Kia Sephia 1.8L (what the transmission is coming from) and a 1998 Mazda Protege 1.5L (what the transmission is going into). Both cars use an intermediate shaft, no ABS and manual transmission.
The Kia's driver's side axle has 28 inner splines and 26 outer splines. The Mazda has 24 and 26, respectively. The Kia's passenger's side axle has 26+2 blank (28) inner splines and 26 outer splines. The Mazda has 26+2 blank (28) and 26 splines respectively.
So the passenger's side axles are the same, spline count-wise, but different lengths. The Kia axle is 24.25" long and the Mazda axle is 22.75" long (1.5" difference). The driver's side axles are different spline count-wise and also different lengths. The Kia axle is 24.0625" long and the Mazda axle is 25" long (1.0625" difference). I'm not sure how much of a problem the length difference will be. Maybe someone can shed some light on this factor?
Looks like I won't be needing new axles. The transmission is coming with the Kia driver's side axle and the Kia intermediate shaft. Since there is no spline difference between the Mazda and Kia passenger's side axles, the Mazda axle will fit in the Kia intermediate shaft. Therefore I can reuse my existing passenger's side axle. As long as the different lengths don't pose a problem.
I will keep this updated with information pertaining to putting a Kia BP G-series transmission in a 2nd gen Mazda Protege.
