I find the temperature is influenced by the setting on the passenger side. I never get full heat or full cold unless the other side is set similar. Other than that, it works fine and the heater in the last Cx-5 was so hot it would make my shoes too hot to touch. I’m hoping this turns out the same.
Since I leave both tied together as in same temperature setting, cabin is cool or warm evenlyI find the temperature is influenced by the setting on the passenger side. I never get full heat or full cold unless the other side is set similar. Other than that, it works fine and the heater in the last Cx-5 was so hot it would make my shoes too hot to touch. I’m hoping this turns out the same.
AC "ECO" mode doesn't exist in US CX-5.
I believe in AC "ECO" mode the AC compressor would stop running when the AC'ed air reached to the specified temperature, whereas AC only mode will let AC compressor running all the time mixing with heated air to adjust output air to specified temperature.
Also, I believe in order to have AC "ECO" mode in Automatic Climate Control of your CX-5, you need i-stop feature.
Thanks. I always have it on ECO mode and never really had any major issues with the heating / cooling. I always knew it had something to do with Economy just didn't know how it worked as the user manual doesn't really explain it either. I also use the i-stop.
