KauaiMP5's "build" Thread
vinyl tinting my tail lights...****** annoying
is there a trick to this????????
im using a hairdryer, spray bottle and a credit card....
its pretty easy i think.... spray bottle with a little soap. spray the light down lightly. hold the vinyl up and heat it. then apply it in the middle or the base of a convex and start heating and stretching from there then clean the edges with a razor blade.
its alot harder on the P5 tails, you have to start in the middle, then heat and stretch towards the outsides. Its going to take a while, alot of heating and stretching in different directions is involved
dude MintyZ spring rate is 28k that's 1563 pounds per inch dam that's stiff. i was thing about going 1,000. but dam
any updates! I love your p5, if only I was in the south and drive this low-_-
I will be a snowplow if I'm much lower out here!
