Kartboy SS install question
Well, if it's too high, it will vibrate against the lever. If it's too low it will vibrate against the exhaust pipe. By good spot I mean somewhere in the middle.
I think that it's due to the bushing and shift rod being so stiff. Make sure you didn't torque down the nut to much on the bushing and test it again.
Torque Setting
According to the FSM, the shifter bushing nut should be tightened to 28-38 ft/lbs (38-51 N-m). The shift lever nut gets 12-16 ft/lbs (16-22 N-m).
02 DX Millenium Red
