K-Sport Coilover Install Pictures
I too have the adjustable awr endlinks but have no problem. I also am lowered 2" all around. take a pic of your install.
Hrrm... I'm not sure what the range of adjustment is, but I know that AWR actually makes three lenghts of endlink. I think you'd have to call them to be sure, though.
Here is my issue. See where the sway bar itself hits the lateral arm? That's my issue. What has been anyone's fix? I don't see anything around it.
It won't go under because the adjustment won't go that far. Nor would there be clearance. The end link would have to go through the arm for that to work underneath
AWR sells rear end links for a Miata. These are shorter than the the P-5's. Some people have used Miata end links for added clearance. Maybe this will work for you also.
justanotheradikt said:
how much of a drop can you get with ksports?
On the ground! :p Seriously - lower than you'de want to take it. Mine are going up for sale again (held for 2 wks. and buyer fell through) unless I here back from an interested party in the next day or so.
what endlinkes do i need to get? i read the forums but didnt get a really good answer... what do i need to purcahse along with the coilovers? thanks
Nothin.. Stock endlinks work with the newest generation of k-sports.
Make sure you tighten the F**K out of the front endlink brackets though. Mine were a little loose and wound up twisting around and broke one of them.
FinalResort said:
i gotta question are they good for dayly driver use?!? for like family use then take it to the track and race?
LMAO
good god no. Unless every road you drive is smooth as silk - you're in for a rough-ass ride. They recommend these guys for track use only, and i honestly woudl have to agree.
I want to put a pair of ksports on my P5. It's a daily driver, but I don't care how stiff the ride is, I just want to be able to take a 20mph freeway onramp at rediculous speeds (70mph) think this is possible with k-sports on stiffest setting with good tires, 22mm rear swaybar, and a rear strut tower brace???
Easily..
These things rock in a track/autox situation. I was smiling from ear to ear.
