K-Sport Coilover Install Pictures
sandman said:
Nothin.. Stock endlinks work with the newest generation of k-sports.
Can anyone confirm this? I'm really close to pulling the trigger on a set, but if I need new endlinks also, I'd like to order them at the same time and have everything I need for the install... Anyone have any other impressions after more time w/ them?
trey
*edit* these are going on an '02 P5..
Mine will hopefully go in soon with my AWR links Front and rear already in place. plus the AWR RSB but now I want to "balance" it for weight.
trey
i used stock endlinks at first but they ended up breaking.
Good to know, thanks. Did you guys get the regular adjustable endlinks on this page, http://www.awrracing.com/pages/pro/prosusp.html ,
or something different like one of the kits? What lengths do I need? Do I need a set for front and rear?
Sorry if these have been answered.. I've read through the thread a couple times and it seems like everyone ended up using different things, or at least describing them differently...
trey
Ok, perfect. Thanks for the info. I'll get a set of front adj. endlinks like in the link
J_Naoto posted. Rears should be good to go until I upgrade bars. Endlinks ordered and on their way...
trey
daedalus said:
No your right, i was running my stock rears until i upgraded the sway bar without any problems. The fronts snapped like a twig.
are your endlinks noisy when you turn the wheel? i tried putting rubber grommets between them and it worked for a while, but they eventually wore out. (huh)
I did the rubber grommets as well on them (at least on the rear for sure, i think on the front too.) So far mine are fine, but then again i've only put 109 miles on my car in the last year so they probably haven't had a chance to wear out yet.
hey yall, i just put on some, and i need adjustment help. i should adjust the front by lowering the sprinch perch, or twisting them down through the bottom? i shud keep a preload on the springs too right?
also will any spanner wrenches from other coilovers work?
