SilverStars are they Blue? .
The Silverstars are are not blue and the BRIGHTEST Bulbs that are not HID lights-accompanied by a ballast and wires. Silverstars are a same color as factory HID kits (4000k White COLOR) but do not have the same light output. Silverstars are by far the brightest bulbs you can get without stepping into the next lvl of HID. Silver Star High Performance Halogen Upgrades are of OEM quality DOT approved and 100% Street Legal.
Does Silver Stars compare to Piaa?
The Silver Stars do compare to piaa and surpass them with less wattage. Piaa attains their light output with more wattage and SILVERSTARS attain their light output through technology and higher quality manufacturing. Silverstars are brighter while using less wattage, without causing shorter bulb life and burning out wire harnesses as do PIAA bulbs. The Silverstars Upgrades are of OEM quality DOT approved and 100% Street Legal. Piaa lights are not Street legal and NOT Dot approved.
What's the difference between Silverstars and HID lights.
The Silverstars are HALOGEN bulbs and do not compare to HID. HID uses a Ballast wires and Xenon gas filled capsule as the same lights in foot ball stadiums and using 35wats. Silverstars are a direct bulb replacement using a filament and without a ballast as HID. Silverstars are the best light output you can get without the big jump to HID lighting.
