just put on my new intake
sleeper3
2008 Mazdaspeed 3 GT
cp-e cold air
yayyyyy
ssssssssSSSSSSSWOOOOOSHHHH
ok I'm done.
also, I spike to 19.5 lbs of boost now. weird.
cp-e cold air
yayyyyy
ok I'm done.
nice man.. I know u get alot of power. But 19.5 iss kinda of alot. Our boost is 15.6 stock. Maybe ur guage is off. But DO NOT run ur car lean.
the gauge reads 0 boost when the car isn't running and the vacuum levels appear to be right on at idle and whatnot. it only spikes to 19 or so, and then settles back down to 17, which is still pretty high, but I'm thinking the gauge is right. I'll have to go get it dynoed and see what is up. also, it's not running lean, as I haven't done anything with the tune, and the MAF housing for the CP-E intake is stock diameter.
Definitely normal. Mine spikes higher sometimes but alway quickly settles back down to 15-16 or lower.
I had the battery disconnected for the hour and a half it took me to put it in. not sure if that resets it, but I'm not worried. I'm sure it'll learn the part if it didn't reset.
I didn't really notice a huge change in power, but the sound is so fun. hard to stay out of the throttle.
i was the same way. but trust me you'll notice a HUGE difference @ WOT in 3rd and 4th gears.
