Just Ordered My Cp-e Intake!!!!!
Ya its on mine, just put it on two days ago. I'll post impressions after I've had it on for a week. Right now I'm just terrified of the freaking car...power increase = scary.
DAMN, Tell me about the install what should i expect from this? any difficulties or anything?
Takes about 2-3 hours...and you need to take your time and have plenty of light. Other then that, its just slow careful work, checking, double checking, and triple checking your work.
Then its just trying to figure out how to shift the car without leaving a trail of rubber on the ground.
nope nothing, the injen gives good results and you can still get a cp-e customiser for just the injen by itself and it will give you good power, but still not as much as the who cp-e intake system, go with the injen if money is an issue, be prepared though for the check engine light which will most likely come on, and the only way to get ride of it is to buy a customiser from cp-e which will add more horsepower to your car and elimate the cell completely!! Thats why i am saying if you got the money go with the whole cp-e intake system you will get the most for you money, and be happy.
so the cp-e intake system is basically providing the intake system and then the customizer chip or w/e it is right? so i can still purchase the CAI riite now and buy the chip thingy later on when i get the money and install it then?
As dyno'd by various members on the forums. (all of this is covered in that giant faq that was link spammed to you about 8 times)
Injen Alone (250ish)
8.5 peak whp
8.8 peak ft/lbs
Injen + CP-E (250+250)
15.8 peak hp
12.8 peak ft/lbs
CP-E/CP-E (540)
20-25 peak whp
20 peak ft/lbs
These are 6 member dyno's, and not manufacturer dynos. (Thus the injen is alot less then they claim)
You can't buy the CP-E intake and then buy the chip later...the car won't run without the chip due to the pipe design. You can however buy the injen intake, then buy the injen fix mafci later...you'll have have a 95% chance of a check engine light without the Mafci.
FAQ's "Again"
CAI, Short Ram, Intake FAQ
http://forum.mazda6tech.com/about25.html
CP-E Intakes and Mafci FAQ
http://forum.mazda6tech.com/about1009.html
Magnaflows don't give any gains. Those who have dyno'd have shown no difference over stock catbacks. Its just aesthetic/sound.
Magnaflow "claimed" 6 hp and 8 ft/lbs...but never ponied up the dyno when it was requested. Considering the primary restrictions on the 6s exhaust are far before it ever reaches the catback, its no wonder most people don't notice any difference.
If you put a 3 inch diameter pipe on the end of a 2 inch diameter hose...do you flow more water?
I personally have read all the reviews on the boards about the magaflows and a lot of people said it did show a different i think it does do something just not as much as an intake or or a big mod, you won't see 25 wheel horsepower but maybe it might be 6 flywheel horsepower, and not at the wheels, I am not sure though. At best it a really good sound mod, and adds more to the top end!!
Nope...actually some of the dyno's have shown LESS power. Most people think it makes a difference because of the sound. Its louder, so it must be faster right?
Once again, think about my example earlier. You've got a 2.25 inch hose, and add a 3 inch hose to the end of it. Is the air flowing out of the hose any faster? The stock mufflers are not a restriction because the flow is divided. We've got a false dual exhuast. 2 pipes to 1 pipe to 2 pipes.
Here's a shot of the exhaust...one look at this convaluted mess, and you realize why catbacks do absolutely nothing.
The catback is actually the "LEAST" restrictive part of the whole exhaust.
Two inefficent cast iron exhaust manifolds with a precat on each one, plus a whole hella lotta stupid bends...giant dents in the pipe (from the machines which mounted the pipes) followed by some sort of "pre resonator", finishing with two main cat's.
And thats before you get to the two mufflers and the main pipe/resonator.
Replace the manifolds with headers, the two main cats with a single highflow cat...THEN the restriction will be at the catback. Wagners current header development is promising some excellent torque gains, and should be done in the next few months.
Based on the available dyno's, and the # of magnaflows being resold (people getting rid of them and yet still owning the car). I'd say they give about a 2-3 hp MAX gain...about the same you'd get from swapping your transaxle and engine oil to full synthetics.
