scatt nasty
Banned
- 08 Metropolitan Grey Mazdaspeed 3
Well I could use some opinions/help.. Yesterday I installed my CS Downpipe and everything went pretty well. It took a friend and I 6 hours due to lack of tools. We had a lift though so everything was ok. Used PB blaster on the 02's and those came off very easily. The turbo studs however were lame. The shop closed about the time I was putting everything back on so we wheeled it into the parking lot and finished in the street lights =) I forgot to zip tie the o2 wires up, and came out missing a tmic nut, but its secure now. Just for the record, this install can be done without swivel ratchets lol. It takes a long time, but it can be done !
Impressions: I have CAI and rpmc inlet going in, and CS DP/RP/CBE going out. The sound is amazing. Its calm and deep at idle/low rpm driving but once you go WOT (well, I can't) it roars. The turbo spools up faster, its louder, this is a whole different vehicle.
Problem: Wheel spin in 1st and 2nd is on command, however I have run into a HUGE problem. If I go WOT in any gear 3rd or higher, whether it be downshift or running through, I get boost cut. Its automatic. any time, on command. The only reason I dont get it in 1st and 2nd is cause its limited. My dashhawk isn't working properly, but I've watched my PSI in upshift and downshift WOT and If I downshift I'm HOLDING 17 PSI and then creep to cut. If I run all the way through I see spikes of 20 and it wants to hold 18 or 19 but it cuts immediately. This is without a MBC or Tune of any kind. IS THIS NORMAL ? I also watched my AFR's and they seem ok.. 3rd gear goes to high 11, and 4th dips down into low 11. Now Ive got another question-- I have the AccessPort on the way... Will this solve my boost cut troubles ? -- Any input would be appreciated. - Scizzle Nistles
