Man what a pain in the ass to install. A couple of things to watch out for if anyone else is going to install their own.
-The O2 sensor harness where it clips in is a PITA to undo. I did buy an O2 sensor socket which helps out.
-The bottom right bolt on the DP flange where it meets the turbo is a PITA to get off. Definitely need a flex joint for your ratchet. Air compressor and impact guns really help out as well.
-The exhaust donut didn't see to match up to well to the CS race pipe I already had. That and I had to use some spacers and a lock washer instead of the OEM springs on the 2 bolts where the DP and race pipe meet. So far no leaks though.
I've only started it to listen for leaks as it was wet out and late and I didn't want to take it on a test drive late at night with all the trick or treater's out. Impressions to come tomorrow. If I remember anything else about the install, I'll post it up.
