Lil_vicious559
Banned
- Mazdaspeed 6
So, since there's no answer, what I get is that you don't know your source, and just guessing what the reflash is doing. It seems you're also convinced that my car hasn't had the reflash, despite the fact that I've posted it has been done several times.
I checked at the dealer, they said ALL RECALLS ARE COMPLETED.
Slow your roll buddy. I hope you are not challenging me on my quotes i stated. For being 50yrs old you have a stubborn way of comprehending and taking into consideration that my statements are coming from my own personal opinion and somewhat legit.
And what proof do you want me to provide.
1.)People are complaining about the power loss of the MS6 after the recent reflash they've had.
2.)people have stated the fact that the car's power is more linear like a V6 rather than the Raw TURBO power you feel from a SRT4 or MS3/MS6.
3.)I said the GM said 70% of the time you take your car in for service, the service department will do most of the recalls that are out.
I know all about the high RPM boost drop. Don't try to BS me with that crap. We all know why those components are being installed. Guys are modding for more than stock power. Bigger turbos require tuning and more fuel delivery.
So in other words your trying to say that in order to gain power and eliminate the Shutter plate valve and Boost drop problem that Bigger Turbo's are required??(braindead
Yeah there are some people out there that are running bigger turbo's, but you don't need to run a bigger turbo to eliminate the problem.
They want to eliminate the stock engine control that drops the boost at high RPM, an understandable MOD. The boost drop under stock ECU operation is not a defect, it's a system control.
Thanks for notifying me, I'm sure we all know that already.
"What is the problem? The monitor function used to detect Short Fuel Trim maximum threshold strategy is inoperative." So tell me, when did this become a recall over the "Shutter plate valve"? It's a fault detection circuit that is not capable of detecting a fault that could occur.
Here smart guy i'll post pictures for you all you have to do now is read look and read.
September 2007 due to recall
2007, CX-7, 2007 mazdaspeed 3, 2006-2007 Mazdaspeed6
once again pictures of the models of the cars for RECALL
Proof of Shutter plate swirl valve.
What is the Problem?
Due to variety of friction the variable swirl shutter valve and position switch, the shutter valve actuator may not be able to fully depress the position switch. This is especially true during cold ambient temperatures and will cause the malfunction indicator light(MIL) to illuminate with the DTC P2006 (variable swirl shutter valve stuck closed) stored in memory. Presence of this concern will not affect the operation of the shutter valve actuator.
WHAT WILL MAZDA DO?
Your Mazda dealer will reprogram the PCM to include the latest calibration, and replace the variable swirl shutter valve actuator with a modified one free of charge. The repair should take approximately one hour to complete. However, it may take longer depending on the necessary repairs and service workload at your Mazda dealership.
