Just another yellow P5 build...
Looks like you have a lot going on. I don't think I would take on the task of modifying the intake manifold the jdmsam way. I'm just going with a ported 626 Mani. I wish I could do more work on my build but I'm saving up to buy the remaining parts in bulk. How much psi do you plan on running once everything is all setup and ready?
Sent from my XT1575 using Tapatalk
Turbo completely cleaned, broken stud drilled/tapped. Turbine/compressor housing alignment pins ground off, turbo clocked to work with the hiboost stuff and proper chra angle for oil flow. Turbine housing and chra painted with brake caliper paint.
And here is a current pic of the clean zone. All the parts that have been cleaned thoroughly and are just waiting. More to come.
I got my turbo oil feed figured out. I see a lot of setups run with just a straight fitting and hose sticking out the top of the chra. I don't like that, so I went with a 90 deg bend in the end of the line with a 1.5mm restrictor banjo bolt. This way I can run the oil feed around the passenger side of the block to the sandwich plate, and it's all very hidden and clean. I'm very happy with it.
Ordered blowoff valve, cylinder head from damian, turbo studs and nuts, and an MP3 steering rack that I will be legitimately depowering. Should be much better than my current looped stock setup.
Really like the direction your build is going in. When do you think the new motor will be in the car?
Thanks. I really don't know when it will go in. I dont want to rush anything, and im trying to do everything as clean, organized and proper as i can. It's my daily, so downtime must be kept to a minimum. There are a bunch of things that I'm trying to put more thought into, things that I can change to be more interesting. I'll be tucking the bay alot more while I have the motor out. Things like the intercooler piping will need to be perfected. I still need a clutch and pistons. Machining still needs to be done. I've got a ways to go. Haha
Rented a valve spring compressor form autozone. They had the same one at oreilly. It's OEM 27040. let me know if any of you have used this type and if it'll work. Also picked up a valve lapping tool and some valve lapping compound.
I cut the holes for the intercooler piping with a 3" hole saw. Came out great.
Got the intercooler and piping mocked up, and it looks good. I was going to trim the crash bar, but the intercooler mounting brackets are nice and solid how they are. I'm not going to mess with it.
My mp3 steering rack showed up yesterday. I promptly began tearing it apart to start the depowering process.
Cut the main seal off.
Then proceeded to cut, pinch, and fold the pipe stubs protruding from each fitting in order to create a good seal on each one. Six in total I believe. And then I removed the pinion shaft from its housing, and got it all cleaned and prepped for welding.
here is a how-to from years earlier...
Hrmm lets see if I can remember all this.
The Rack is what 20 years old? So I wanted to see if it fit before I even started to rebuild it. It seemed to be a pretty close fit. The secondary mount needed to be slid in like around a inch or so. However its not just a rubber mount, its also the end of the rack. It holds on the pass side boot, and looks like maybe a seal or something. But alas I squirted some lube under the hard rubber and twisted it down in my vice and around 10 5/8" later it was match (but now you can see the boot is super extended). Next I found that to get the same ball to ball the outer tie rods where only on by like 3 or so turns. I didn't feel safe since some of the rumble strips at road America are pretty harsh. So I went to my local parts guy (not autozone) and told him I needed the same outer tire rods but with a bit longer length. Two min later he cam out with what I needed. $41 later I got new tie rods (not that the old ones where even slightly worn). Cut them down a touch and spun them on and walla! I did notice when I was checking out the secondary mount (had the boot off) that the grease was like new and there was no play and the rack felt in very good condition even the outer tire rod ends had no play. So I chose not to rebuild and I could care less on the looks since its a race car not a show car. So in it went. Like three times. The first time I realized that the primary bolts had to be changed, and the primary mount needed to be cut. I had to remove the center (between the bolts) to make room for the round mount, since the power rack was flat and the manual was round. so $5 later I had new bolts that I had to cut down. Also the steering was a bit shifted. So centered that and pulled it off to try again. Second time it went in. But it was cocked out forward on the secondary mount. Thought and thought and the only thing I could think off was to twist the hard rubber mount 180* and reinstalled a third time. This time with the secondary hard rubber mount backwards the rack was straight as a arrow (couldn't believe it). Mounted super solid. No binding in the steering. And spindles and steering wheel are all straight. Next I had to loosen a bolt that was pinching the steering shaft so the "u" joint could slip about a 1/4" down over the rack input and reinstalled bolt re tightened shaft pinch bolt and done. The rack weight diff was 5LBS for a overall weight loss of 20LBS. Its not worth the time. But I only need to be quicker by 1 second to be in-front of the fastest miatas in Midwest Council and into some real competition. Team this with a quiafe, and some other weight loss goodies I think I will be happy. I can't say for sure if this mod is dumb or good till april (spring training). Then I can comment on the drive-ability, paddock-ability, and the ease of getting around in the engine bay without all the hoses, pump, belt, and fluids. But for sure I would hate to deal with a un-powered power rack moving it around by my self in and out of the trailer, and moving it in place in false grid.
Here are some pics. Yes some. Sorry I hate stopping when I get going.
attachment.php
attachment.php
attachment.php
Update: It is awesome! It was sooooo hard to learn how to drive/race with two hands. I know it sounds dumb, but I have always driven with one hand. And getting around in the pits is not bad at all. No problems. well maybe my tires being to big and rubbed a bit when I spun out, but no problems. I can now under stand the "feedback" thing people are talking about. If you get into a corner just perfect you could let go of the wheel and the car just 4 wheel drifts through with no steering input. Also the ratio is higher so any jerks of the wheel are slowed down making me look like I know how to drive. nice and smooth. One draw back is if I start to spin its a lot of work to recover. I need to learn how to recover quicker as I spun in my first race.
No good?
That's great! What was the rack out of? My setup is different for sure. Quite alot heavier I bet. The feel is great, I'll never go back. It's too much fun to drive. A bit scary at first. You can't physically turn the wheel as fast as before, and that takes a little getting used to. But, it's so much fun. Parking lots suck though, especially when dealing with driveways and speedbumps with my ride height. Makes getting sufficient angle a little more challenging.
ARP head studs came in today. Along with some more silicone couplers, and a crankshaft repair sleeve, because my rear main seal area on the crank is a little bit pitted.
Cylinder head came in today. Pulled it all apart and everything looks good. Going to lap the valves, and replace the valve stem seals, and hopefully that will be all that's needed.
I got a valve spring compressor off ebay for 16.99, and it did great. Very easy and fast to use.
