xDanielSenpai
- Mazda, Protege5
So I just finished with the timing belt of my MP5, Everything turned out great!
But then i screw up
i was tightening the bolts on the valve cover... and so one of them split in half leaving the lower part of the bolt stuck to the engine. Its the lower left beisde the timing cover.. So i was wondering, where can i buy more bolts for this car?
Also the car has been out for about 3-4 months now, once i finally turned it over it was hesitating to start until i pressed the gas pedal. Is that normal? Whats the best way to tighten the crank bolt w/o an impact wrench? Annnnddd once the engine settled down for the first time, it stayed idling lower than 1000rpm like half way between 0 and 1000 is that okay?
