Depends.
I had to install the Racing Beat Springs once, so this was even easier.
One thing of note: zero out the camber plates, then set the front bracket all the way to positive camber. That will put it close to zero. If you use the other extreme of the elongated hole, you'll have TONS of negative camber.
I'll write up a more extensive review/install tips later once I get some of my kinks worked out.
