Issue with manual key
Hey everyone. So winter is being rough and my locks got frozen while car was running, I tried to push buttons but key did not react at all, so I tried to use metal insert to manually open...the key turned in both direction but lock did not do anything, ( I got in through the trunk) so what might be the issue the lock ?
Water probably entering the door through the window seal and then freezing...If it works after it warms then it's probably that.
