Husband or not. We are trying to tell you something. When ever you mod any car for that matter you must reset the ECU. It is only common sense. You are bringing in more cold air. ECU must adapt and recalibrate for the cold air coming in. How is the ECU going to know what you have done if you have not reset. ECU right now is not trying to justify for the cold air and a/f has not adapted. Therefore could be the leading cause that your going to through gas like water.
But you know what, if you don't want to listen to all of us, good luck. Just don't understand why anyone would ask a question, receive an answer, the correct answer for that matter, and then not do anything with it or seems like not even believe it.
Good luck...
