Is there something wrong or is this normal??
knowledge007 said:
Husband or not. We are trying to tell you something. When ever you mod any car for that matter you must reset the ECU. It is only common sense. You are bringing in more cold air. ECU must adapt and recalibrate for the cold air coming in. How is the ECU going to know what you have done if you have not reset. ECU right now is not trying to justify for the cold air and a/f has not adapted. Therefore could be the leading cause that your going to through gas like water.
But you know what, if you don't want to listen to all of us, good luck. Just don't understand why anyone would ask a question, receive an answer, the correct answer for that matter, and then not do anything with it or seems like not even believe it.
Good luck...
(boom05) (drunk)
what's your trip computer reading for gas mileage?
mine is at 21.8 right now, which i think is pretty good for never driving on the highway and it being 100 degrees here every day. i don't ever fill my car up so i can't say anything about the rapid drop...
knowledge007, it is not required to reset the ECU for every mod, BUt when you do the car tends to learn and adapt faster, THATS ALL.
as for decreased mpg or the gas gauge, ye mine drops fast also at 60-70 miles. i also recently installed a MSCAI and last tank of gas got me 14 mpg.
I was hard on the car trying to verify i had all of my extra ponies. i'm pretty sure i accounted for all of them :D
For MPG...that seems to always be the same 24.8 or so....but I NEVER get that mileage per gallon. :(
If you followed the DYREKSHUNS on the install of the CAI, you already had the battery disconnected for the length of the install.
p.s. I had heard that disconnecting the battery and pumping the brakes will bleed all the power from the car's ECU. Draining the caps is something will refer to it as @ work.
I know I'm pretty much a new unknown member but I have plenty of years modding Focus's. As a rule of thumb always disconnect the neg. battery terminal for anything the ECU may effect. If you just throw on a CAI and fire the car up the ECU is going to think there is a problem due to the fact the car isn't running the same way it did before the mod. The result will be the ECU trying to compensate with increasing the fuel flow. You will pretty much be telling it the air is actually cooler outside then it really is, thus leading to the crap MPG. If you reset the ECU, when the battery is hooked back up it recognizes a change and sets the air fuel to were it needs to be. Although I have never used the brake thing before interesting idea. Bottom line is, it's always better to disconnect the battery to be safe. Not only does it make it easier for the car but it can prevent any shorts or problems depending on what your working on.
The reason it has to be disconnected for a period of time, or use the brake method is the ecu will hold a small amount of power to keep everything as it should be.
Working on the Foci we used to disconnect the neg terminal just to reset the ECU to factory specs. As years and months go by the ECU learns the temps and how you use the car and it will change settings. By disconnecting it you automaticly rest everythign back to factory specs. Think of it as the brain. It can learn small things that change the way it performs.
Geez.....i guess I will see what happens with this tank of gas....and go from there. I have about 105 miles on my car and it is not to 1/2 tank yet. So we will see. :(
