is there a way to smoke out my tail lights?
While I really like all the clear on your car, I think it'll look even better if you smoke all the lenses - it'll definitely give your car a more aggressive look. I ended up not using the second set of clear lenses - I got the overlays for the sidemarkers and taillights from bluebatmobile instead. (That way, if the cops have an issue with the darkened lenses, it's a lot easier to get rid of than trying to remove the spray on tint.)
true
it may be just a bit easier but not too too much... all you need to remove this stuff (depending on if you use clear coat) is rubbing alcohol and some polish. I had everything on my car (sidemarkers, quarters, tails, fogs) tinted. the fogs were with overlays but that was only because I was too lazy to take out the fogs :D
I even had the car inspected by Mazda for the state inspection and they said it was fine and even complimented me on the look (rofl2)
really, thats cool, im going today to get the stuff thanks guys and girls!
Not to get off track or anything, but is it illegal to smoke your headlamps? Even a little bit? I imagine its the same thing as the Black-Outs some of the older Cameros and Sport trucks put on their headlamps during the day and then have to have off at night.
The only reason I ask is because if I smoke out my tail lamps, I think it would look stupid if I don't do the corner lens and headlamps (if I can) as well.
II-Savy said:
I would think a light coating would be hard to tell it was different from stock.
So then what would be the best thing to use? Would Nite Shades be too much? Think maybe a tint place would do all my lamps?
here attached
SenorCorwin said:
here attached
wow thats really dark, did u do it over the stock tail lights?
i wounder what its gonna look like when i do it on my altezza lights.
were you on decarie at lunch time ?
i think i saw you turning left on Par at around 12h30
yep, was on my way back from gettin f00d
i finished crossing the street, turned around and saw your car. wasn't sure it was you at first but then i recognized the stickers on your door
