Is it Powerful enough?
it will, but those are just bad subs.
that amp will do 100x2 for the front stage, which is great for the alpines.
it will do 300x1 on the rear stage bridged, which is great for a lot of subs on the market.. itll actually be plenty for the duals... but they suck. seriously.
i am going the same way,for the pseakers,its ok...
and these alpine speakers are great,really good quality...
but please,dont put that kind of bad subs with alpine speakers,youre going to regret it..
save some money and get yourself some alpines,or anything worth the money...
dual=low price=low quality=crappy sound...
you can get some good alpines for around 200$,that way you d be satisfied!
take a look there just for example...
www.crutchfield.com
(guitar)
Thanks,
which alpine subs would you guys recomend?
And Will the stock battery be able to handle the wattage fine or would you suggest an Optima battery??
any alpine subs,depends on your money,higher quality = more money=more power needed..
for myself i have a double voice coils 12" type R,i love it...
if you plan on adding an amp,a good thing would be to get a capacitor,like 1.0-2.0 farad,that would help your alternator and the battery,(keeps the dimming light away)but for sure an optima battery is the best,or a stinger,but $$$ for the stinger...(hear ya)
i d say go with the capacitor first,than you will see your needs for the battery,but dont get the stinger you show in the previous post,its way to big fo your car!!!
if you look on optima s site,they have a model that fits almost perfect,just a small bracket mod and your good,i dont remember the model number,but i use to have one,i ll try to find it for you...
woops, well i was considering getting either a battery or capacitor beacuse the running the subs may make the lithgts dim, and i just want to cause less stress on the battery.
woops, well i was considering getting either a battery or capacitor beacuse i will be running subs ,and it may make the lights dim, and it should cause less stress on the battery right?
Wow good info. I did not know a lot of that. I have a rockford power T2 series 12" in mine with a Rockford 3000 Watt Power sub amp. Way to much for these cars in my opinon. I had put the system together for my blazer that died and I have boston Acoustics all round.
Well my budget is only around 800ish.......................i dont want to spend a lot, so far i have bought alpine spr 17s, (130 ebay), rockford PEQ 30$, rockford fosgate T600-4 ( 390 ebay) looking at a tsunami 2 farad capacitor for (90 ebay) or maybe an optima battery for around 200ish.......................... and then looking to spend the rest on a sub and installation.
The sound deadening stuff i saw some Dynamat for 20$...........
( http://www.crutchfield.com/S-OK5KCQ...sp?g=181250&tab=essential_info&i=15410415#Tab )
i saw some of these ( http://www.crutchfield.com/S-OK5KCQ...w.asp?g=762&I=237XT652&search=sound+deadening ) maybe to protect the speaker i dont know if the speakers will be protected once they are replaces can you lend some insight on this - thx
yea i will be getting the 6.5's, i went through your install gallery but half the photos didn't load.....And i plan to put some soundeadening and try the Big 3.
hopefully my parts arrive soon and i can get started, thx for the help
hmm i just recieved my t600-4 and its total rms power said 695, so how is it that the amps have all different rms power numbers and how did mine get so high?? -thx
