is it dead ?
Best thing to do is to have a compression test run on both rotors. If the compression is within spec or slightly below, the motor should start. If only one rotor or no rotors show compression, then the motor may have bad apex seals or other bad seals. If you have already tried starting it with ATF fluid and it is still not going, then there may be a compression or fuel problem.
I gotta look at mine sunday...heh...it will fire up, just has to be "fed" gas....lol...gotta be a the carb or fuel pump...errr...
