is 4ga too big
VFR pilot
'03 P5, '94 Miata, '00 VFR, '01 SV
so i'm gonna have 1 amp installed...prolly an a/d/s amp w/ about 50x4, anyway i bought the 4ga 4ch amp kit from knukonceptz and i'm thinking the 4ga may be TOO BIG, should i have gone w/ 8ga??
well, i really don't plan too.....once it's done, on to the engine or exhaust........but chances of me going w/ some killer bassing system is slim to none.........too old for that kinda stuff :p
you couldve got the 8ga wire kit, but having bigger wire wont hurt anything. its having too small of wire thatll kill ya.
Stick with the 4awg and dont look back. I've seen too many people install 8awg only to have it all pulled out and have 4awg installed.
or be like me, had 4 guage installed only to pull it out and have 1/0 installed
The only issue you're going to have is rather your amp will readily accept 4g. if it's designed for 8, you may have too small of an opening. in which case, you can either splice on a bit of 8g wire, or install some sort of a spade that'll neck it down small enough to fit.
yeah like sndsgood said, 4 ga will not fit into an 8ga port on the amp you will need a 4ga distro block which usually splits it into 4 8ga slots
