- 2021 CX-30 Prem
Hey everyone,
Just wanted to let you all know of a workaround I came up with that allows you to shuffle via Bluetooth.
I use an iPhone 4 with a app called Muxica instead of the builtin iPhone music app. It gives you about the same functionality of the regular music app, plus the added bonus of being able to crossfade songs
The only thing you have to do is start the song via the Muxica app by tapping the iPhone screen, and then you can put the phone in the center console. There is a shuffle option in the queue (similar to a playlist you would create on the fly in the regular music app). Now when you are playing the tracks in your queue they will be shuffled, and you can skip to the next track using the next and previous buttons on the radio or steeling wheel controls
If you receive a call or switch sources, you will need to open the app on the iPhone and tap the screen to start music playback again, the play button on the radio will not work. The only other downside is you have to use Bluetooth so you can't use the Centerpoint system
