iON Performance said:brianmcd - The 1-piece integrated down-pipe is being sold only with the hi-flow cat section or the race -pipe section. You can optionally purchase the 3" cat-back section at a later date if you so wish to. However since all the piping is 3"; you won't be able to hook it up to the stock exhaust. It would have to be at least a 2.5" aftermarket cat-back set-up; at which point would still be required to be modified to fit properly with the components. Alternatively, you could get a custom 3" cat-back section made.
i knew someone would say that. i am only asking as to the dianmeter to see if the combination is = to 3 in. thats all nothing more. i am in no way trying to make an exhaust or coprying anybodies ideas. i was just assuming that they had used a peice of 2" and 1" but as we all know that is not = to 3". i wanted this info to see how it compairs to the stock part as for internal area. i am trying to get ALL the facts before i buy something.********** said:With all do respect, you keep asking other vendors specs of their products and methods of testing. Almost like you are trying to copy their products. Its just a hunch, please correct me if I am wrong.
Thank you.
Yeah haha bad typo lol.jflo said:i think you mean separate channel for the wastegate.
Well this is not always the case. Do a CFD of 2 different flow at 2 different pressure just dumping together into a large collectdion basin isn't the smartest idea. Remeber you want to reduce back pressure, and if the flows from wastegate and turbine exits are routed smoothly until they don't interfere than merge together, then that will cause less back pressure than just a huge tube collecting both. This gives a better spool up time for your turbine, since the pressure difference between turbine inlet and turbine outlet is greater.********** said:Your DP off the turbo seems to be less than 2.5 inches. Seems a little restrictive having the wastegate discharge the same size as the turbo discharge. Almost like your are choking the turbo before it makes it to the 3in exhaust.
Good luck with your product, ours will be dyno'd in the following weeks. We can compare results.YuYuRena said:Well this is not always the case. Do a CFD of 2 different flow at 2 different pressure just dumping together into a large collectdion basin isn't the smartest idea. Remeber you want to reduce back pressure, and if the flows from wastegate and turbine exits are routed smoothly until they don't interfere than merge together, then that will cause less back pressure than just a huge tube collecting both. This gives a better spool up time for your turbine, since the pressure difference between turbine inlet and turbine outlet is greater.
(pow)********** said:Good luck with your product, ours will be dyno'd in the following weeks. We can compare results.
Thank you.
what does that mean?(confused)jurgs01 said:(pow)
I think it's a thumbs up, or at least that's what I thought when I clicked it********** said:what does that mean?(confused)
jurgs01 said:I think it's a thumbs up, or at least that's what I thought when I clicked it![]()
