Introduction... long time 2006 Mazda5 owner
mr.fusion
2006Mazda5 TouringAT 2013CX-5 TouringAT
Try to make this short. Seems like a great forum. I'm sure I've checked it out a time or two but had not registered until now.
Bought my 2006 Touring AT new, to be my commuter/work vehicle that I drive and work out of all day, every day. It's been a fantastic vehicle, if it were not for the horrible suspension and tire eating issues. Leave it at that....
Now has 209,000 miles on it, and glad to say that it has never been in the shop for anything except regular maintenance, stuff like new shocks, brake pads, tires, oil. Check that... I did bring it to Mazda while under warranty at 35k to complain about the tire wear and clunking suspension, and had new sway bar bushings, etc. Also did the recall on the door latches.
First 150,000 miles, did nothing but oil/filter changes, trans flush around 100k, and maybe a couple air filters in there somewhere.
around 160k, front suspension work, struts, control arms, bushings, alignment, etc. (done at a local shop, $1300... all other work I've done at home)
around 170k, front brake pads and partial trans fluid flush.
around 195k, rear brake pads, spark plugs. (plugs were still working fine, just figured it couldn't hurt LOL)
around 205k, trans fluid flush, rear shocks... cheap ones from rockauto.
Still has original rotors, but fronts have some warp feel and will be replaced if I decide to fix up and keep it. Will probably flush coolant and brake fluid too, maybe a new belt... stuff like that, that's still original.
So basically, it's just had oil/trans changes and one round of brake pads and shocks... in 200k miles. Suspension gets worn out so fast it could be done with every other oil change, and takes the tires with it.
I've always used Wix filters and Mobile1 full synthetic. I use the extended life "15,000 mile" stuff, unless it was out of stock. (@26 bucks for a 5 qt jug at walmart) I try to get it changed at 10k, but have run it to 15 a couple times. Anyway, seems to be good enough.... engine runs great and seems like it's ready for another 100k easy. I don't drive like an idiot, but I do drive a little aggressive around town as mentioned. Cars are like dogs... they like to run, not walk... (whistle)
I've never really liked how slow and lazy the AT shifts if you are trying to get somewhere. It was getting worse... delayed, 3-2 downshift when rolling around corners etc... made for a hard shift. Fresh trans flush cured most of the shift issue (Valvoline synthetic multi vehicle), but I've picked up the habit of simply shifting it myself, so it's in the gear I want, when I want it. And it's a lot more fun getting on and off the highways when you drive like it's a manual. (braindead Now I rarely just leave it in D unless I'm Sunday cruising. Trans does still feel nice if you drive slow. LOL
This car is kinda like my old 1.8L Mazda-powered Escort GT 5 speed that ran great until it was wrecked recently with 230,000 miles on it. Lots of highway miles, but ran it plenty hard at times too. Escort had one set of brakes/shocks and wires/plugs and that was about it. Did not have all the suspension/tire problems though. Couldn't kill the engine, just the body ha ha ha .... RIP GT
Mr. Fusion your 5 should be crowned as the queen of all 5's here at the forums. What a champ your little 5 has been with all the work you put her through and all those miles that you have raked in her. Your 5 is definately an inspiration. My 5 has 100k less then yours does and even though it also has the little suspension annoyances I love my 5!
Welcome to the forum!
I also have both of the same vehicles!
I didn't see it on your list, but thought I would make sure that you also changed the cabin filter inside the car also?(thought)
I might be doing my first brake pad change soon on mine here when I hit 100k miles. I was thinking about selling the Mazda5 to purchase our new CX-5. However, I could not find anything better to replace it with for the money. So I kept the Mazda5, and I am back to having two Mazdas in the driveway. (whistle)
+1
Welcome. Keep us updated on how she holds up.
Will do. Thanks.
Um, haven't changed the cabin filter yet lol.
Plan for now: I'm taking a road trip in the CX5 next week... Iowa to Florida for a week or so. When I get back, I'm going to pick up a few things from Rockauto (cheap struts, axles, sway bushings, etc) and take it to a mechanic buddy that won't kill me on doing a a couple hours labor to get the axles swapped out. Sounds like the axles are a PITA to get out, and I would rather not swap struts... plus he can do an old school alignment which is probably a good idea for this car.
Meantime, it's another week of work with the rattle5. At least it's only noisy at low speeds. :)
Yay, you own a CX5! How do you like it? I look forward to them being available on the used car market :p
I have a huge request that I hope you can help with. Could you take wide angle pictures (or multiple pictures) of the CX5’s rear underside? I’d like to see if CX5 hitches might fit the Mz5 (see thread below). If possible, put a measuring tape against it to show length and width. Also, see if you can visually gauge if bumper clearances are similar too. There’s no urgent need to do this but it would be great if you can!
http://www.mazdas247.com/forum/showthread.php?123813010-Another-Hitch-Thread-But-With-A-Twist
