Interchangeable Wheels
2016 Mazda CX-9
Hi everyone,
As you may all know, I own a 2016 CX-9 equipped with the factory 20-inch wheels. I’m considering installing the 21-inch wheels from the CX-70 and wanted to confirm compatibility. From what I understand, both vehicles share the same 5x114.3 bolt pattern, but I’m unsure about other potential fitment issues such as offset, hub bore, brake caliper clearance, and overall wheel-well clearance with the larger diameter.
In addition, would the existing lug bolts and wheel locks from my CX-9 work with the 21-inch CX-70 wheels, or would I need different hardware?
Has anyone attempted this swap or looked into whether the CX-70 wheels are a direct fit on the CX-9 without requiring spacers or modifications? Any insight on whether the OEM tire sizes would work without rubbing would also be appreciated.
Thanks in advance,
Shawnee
My biggest concern is that the CX-70 has a 9.5” wide wheel with a 45 mm offset. That’s going to give you about 179 mm / 7.05” of wheel backspacing. I’m not familiar with how much kingpin clearance the CX-9 has, but I’d bet that the CX-70 wheels are going to test it.
