<div class="bbWrapper">Because of the steeply ranked and long windshield in the 5 (minivan type), you could probably get great reception by mounting it on your dash where it meets the windshield and just tucking the wiring into the panels. That way it can’t get stolen (not a real concern, though), it’s very easy to install, and you don’t have to see it on the outside of the car (some think they’re an eyesore).<br />
<br />
Alternatively, if you decide to install on the roof (the best option, but most labor), find a spot near the edge of the roof, and then you just tuck the antenna wire into the nearest weather stripping and pass it in through a door, then just tuck under panels/carpet until you get to the Stiletto mounting location.<br />
<br />
Be forewarned, however! The Satellite Radio antenna wires are DELICATE! If you slice through the insulation or kink the wire, the antenna is more or less destroyed. Just be careful that if you have to loop it, make sure it’s looped in at least 1-2” diameter so the wire doesn’t crease. Also, if you use a flathead screw drive to tuck the wire into weather stripping or panels, use care to not strip the wire. It’s got some durability to it, but if you do crease or strip it, it’s toast.<br />
<br />
Good luck! <img src="https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png" class="smilie smilie--emoji" loading="lazy" width="64" height="64" alt=":)" title="Smile :)" data-smilie="1"data-shortname=":)" /></div>
