Installshield 2
Gothenburg Superiority
Good points...I was trying to keep away from the 33% efficient gasoline engine theory, and all the potential energy of gasoline...If I would have included all that math, it would have touched more on the physics and chemistry behind air pressure...DSMConvert said:IS you're half right....what you said regarding airflow and top hp is basically correct, BUT psi is an important factor in determining eff. ranges...psi is also a function of heat, as we know air expands with heat. The psi is the work output of the turbo, that is the force representative of the energy required to produce a certain pressure. As you increase pressure you will always increase heat(laws of thermodynamics), thus as heat increases, eff decreases(covered in 100% eff combustable engines and such in physics II). SO though yes psi has nothing to do with airflow persay, it does have everything to do with intake temps and eff of the system at hand....the t25 will lose its eff at 18-20psi regardless of the cfm is flows at those pressures...the reason bigger turbos have higher eff boost levels is b/c it takes less energy(heat) to produce a given psi...but back to my question is there a particular year IM we should be looking for or will any fsde work?
I was just trying to illustrate that the turbo has two limits...and I only focused on the one...A) a given turbo can flow enough air for a determinable amount of hp...for any engine...and B) a turbo can build a certain level of pressure above the ambient pressure entering it...But depending on the engine the turbo is hung off of, maximum flow could be reached before the compressor trim bites it...My theory was that the turbo is pushing its maximum air in this dudes engine well under the graphs inefficient zone...as far as boost...
Leave me out of this though...ha, I don't even own a turbo...
