Intake diameter
Gavin
Can anyone tell me what the interior diameter of the intake manifold runners is for the 2.0L? And/or what the area of the intake ports are, where the intake manifold meets the head?
Thanks
I don't believe they're round, so a direct diameter may not be possible. An oval/ellipse is more like it and should be able to get a very close estimate by that means.
flat_black may be a good source for that (or anyone else that has the head/intake mani off).
Doing some volumetric efficency calcs?
Yup,
I'm looking at starting up a small NA project. Nothing terribly drastic, Im just looking to improve my throttle response.
I assumed that the intake ports on the head would be more ellipsoidal than circular. I thought they might taper out to a circular cross-section over the intake runner length though. Either way, if anyone can enlighten me with some intake runner/port area information Id appreciate it.
Well, I'm ASSUMING the intake port is 35mm by 50mm... I never measured 100 percent! I totally spaced that! Ahh, well.
At any rate, assuming it's 35 by 50 oval, we'd take the 35, and use that as the diameter, giving us a 17.5mm radius.
17.5mm in radius gives us the critical info for the pi*R^2 equation, leading us to the following:
pi*17.5 = 54.978
54.978^2 = 3022.58... = Area of the radiused ends.
Now we calculate for the area between the radius.
50 - 35 = 15 = The width of the rectangle between both radii. Height is eqivical to the diameter, 35, so:
35 x 15 = 525
And in conclusion:
3022.58 (area of the radius) + 525 (area of the rectangle) = 3547.58 (total ovoid area)
But those are just based on guesses, as far as sizes. I would dare say I erred on the large size.
Oh, and the results would be expressed in mm^2. (Millimeters squared)
Thanks for the rough info flat_black, that should be enough to get me started.
If anyone has any exact figures for me to work with, lay em on me man.
Maybe Ill just go and pick up a shop manual for the pro, that should tell me everything I need to know.
Flat_black, I just noticed a problem with your math.
Area of a circle is pi*r^2, not (pi*r)^2
So the area of the radiused ends would be:
3.14 * 17.5^2
= 3.14 * 306.25
= 961.625mm^2.
Total area would then be closer to 961.625 + 525 = 1486.625mm^2
Im not trying to piss on your help or anything, just noticed that small error.
