Installing the Auto Climate Control in a non-GT?
2021 RDX A-Spec
Is it at all possible to install the GT's climate control system in a non-GT trim CX-7? I'm talking about replacing the controls below the stereo and activating the dash display. Is it at least possible to activate the dash display without adding much new hardware?
I'd like to know too.... I mostly want to have the AMB temp working like my RX-8's.
I don't think it'd be that expensive to plug in an ambient sensor to the car's CPU. I've read that the trick works on other Mazda models, and the sensor is only $60 from your local parts department. I'm curious if the same applies to the CX-7, and if anyone has discovered where the sensor would plug in.
Now installing the auto climate control might be expensive, since those boxes usually cost quite a bit. But all I care about is having something display in that horrible blank spot on the radio display. Even if it is a "no-duh" display of my manual climate control settings or the outside temp.
yeah that really is cheap on my sport. empty s*** where u can see there should be something there...if it had climate control, w/ dispay by window and outside temp, i would have no complaints...
