installing gauges
bvines18 said:
how do i install my reverse glow gauges on my 2000 protege lx?
I found it rather hard. I ended up snapping my fuel and temp needles off tryin to get em on. I dont think theres a way other than slipping them over exsisting gauges
I tried putting the reverse glow guages on, and I broke my fuel needle. They guages will not fit unless you cut them. They were designed incorrectly.
what would be the best way to replace a broken temp needle. i broke mine today installing the gauges and was wondering what would be the easiest and cheapest way of fixing it
:sigh: What i did was i just bought an instrument cluster from the junkyard and transfered the fuel and temp gauges over to my exsisting speedo and tach. that way u still have your true milage from your car and not the milage from the car at the junkyard
all im looking for now is the temp needle/motor. i have finished everything else and that needle being missing is annoying. so where could i get just the needle to put in and not have to buy the whole cluster for $400?
U cannot just replace the needle....needs to be the gauge itself. I purchased a whole cluster from a local junkyard for $75. Check around your local junkyards or use this site http://car-part.com/ as it was how i found the junkyard i bought mine from. If u cannot find one local, maybe one will ship to you. Might be a good ideal to check on ebay as well
hey bvines18 just curious as to where you got your reverse glow gauges from. I recently bought a 2000 Protege LX and have only been able to find the gauges for the DX model... maybe I'm just looking in the wrong places
oh and be very careful when installing them. i broke off my temp needle and my tach needle is off because i pulled it up. just leave them how they are and be careful sliding the gauge under the needle.
patsfan4life said:
are the needles really that fragile? what are they made of
the part that you see is just plastic but what i broke was the very thin metal rod that connects the needle with the, i guess, motor that spins the needle. the rod was about the thickness of a normal paper clip.
bvines18 said:
yea i looked on ebay for a while and only found those DX gauges. then i found a place called pro car parts.
here's the link to the actual product:
http://www.procarparts.com/store-li...D=36&maker=MAZDA&model=PROTEGE,+323&year=2000
Thanks! they look so cool once they are all installed but I don't know if I want to risk breaking off al my needles after reading through all the installation horror stories, plus I live in Canada so kms would be preferable... Maybe once I've had the car for a little longer or if I start to get bored with it I'll take the plunge
yea they dont show the kms very well so if i were you id hold off with those until you were just too bored and had to do something to your car
Back from the dead .. but I just wanna offer a gauge cluster to anyone that might need it to replace it due to a broken needle. I have a 02 P5 with white faces, and 03 P5 with silver faces. PM if interested.
P.S.: I'll post this in the FS section with proper pics soon too but I figure I could throw it in here too for those who don't keep their eye on the FS forum.
kevINm...if you still are thinking about buying those reverse glow gauges, i went and put in a mazdaspeed gauge cluster so i have the gauges laying in the garage and could sell them to you if you still wanted them.
New Threads
