I'm thrilled you like it. Nice pic thanks!!
i love it, so much better than a $200+ STS, and the install took like 2o minutes
I just installed mine Thursday. Took 15 minutes, really easy. The new powdercoat is amazing (glossy black). Drives like the STS equipped MS3 I drove a couple of months back at less than half the price! Now that I got the shifting down the 2-3 and 3-4 shift are lightning quick. One or my favorite mods I have done. This is in combination with the SU shifter bushings/AWR MM.(breakn)
Thanks Jbarone!
And now you can see it since I just replaced the stock airbox with a CPE Nano.You're welcome, I'm glad you like it. The powder coat is so tough too. It will look and last like new for 10+ years.
Thanks,
Jamie
Add me to the list of members that have installed jbarone's shifter plate. It works very well, in fact, I like it better than a short shifter setup. The factory height handle fits my purpose better and the shifts are shorter, but shorter on the 2, 4, and 6 side, which is better to me. A plus is it can be installed and removed if needed, very quickly.
Overall good value, good performance.
just order a blue one. looking forward to it. thx jbarone!
I have my own version of the Rotus mod and decided I should try a lighter weight. I just installed one of JBarone`s weights and there is a definite improvement. What I noticed the most is that under spirited shifting, it doesn`t feel like the mechanism is trying to bounce back out of gear after each shift.
Nobody has any thoughts on this?
Is it just my car, or did anybody else`s factory weight stink to high heavens? I had it in the house and within a few minutes, I had to put it in the shed.
Reminded me of internal parts saturated with oil that got cooked.
If you`ve ever smelled a rod that came out the side of an engine block, you`ll know what I`m talking about.
i had this plate installed for a week and had to take it out and install the stock one again. i didnt like how shifting felt so heavy and stiff. i luved the short throw of it but the stiffness killed it. just my opinion on the part.
