Installation of FMU!!!
This is for all the turbocharged proteges
that have a Vortech FMU. If you guys can help me or send me pics of your setup.
Thanks
this has been discussed and explained in previous threads do a search and you should find alot. But in other words take your vacuum line goign to the stock FPR put a T in in run one vacuum line to the stock FPR and one to the FMU. Then get a high pressure fuel line and run it from the outlet of the stock FPR to the inlet or top fitting of the FMU. Then get another piece of the same fuel line and run it from the bottom fitting on the fmu and connect it to the stock line that came off your stock FPR somehow and your done nothing else to it.
