Do you have to remove the bumper to install fogs on a 08 speed? I pulled back just a little bit of the fender well shield and cannot see much of anything. I am not sure if i need to pull the wheels and pull all the fender well out to get to the assembly of if they can only be installed from the front? Damn there is a lot of plastic on the front of this car, under, over, side, in, around and tons of tabs... Why couldent it be a crawl under your car, undo harness, replace bulb, replace harness, etc... Not remove half the plastics.
