YellowSpeed17 - the hard-pipe kit will be available shortly. We've already done several prototypes and working on the best material combination to give the most heat insulation inside and as much reflectivity outside. The price will be ~$350US or so which will replace the inlet from stock air-box -> turbo, from turbo compressor out -> I/C, from stock I/C outlet to throttle body as well as from stock airbox to wheel well.
KyRaceFan - The hard-pipe kit can be used with the FMIC upgrade. If you buy the hard-pipe kit now, you'll only need to purchase 1 pipe (a new Turbo->I/C pipe) and the I/C itself, which will be cheaper then buying the whole FMIC kit. We design our pieces to be upgradeable.
