Injen CAI
Kimo5d3s
Mazda3s 5door
Does any one know where the air filter lies in Injens CAI application? Does it differ than AEM or is it the same location?
anthony2558 said:
it lies between the wheel well and front air dam.
Does the fron bumper cap need to be removed to install the Injen CAI. I checked the instructions and theya re stating that the front bumper cap needs to removed in order to install the air filter protion of it.
It depends...removing the facia makes the cai instalaton 30%-50% more easy...but thats not including the removal of front facia. not jackoin the car and not removing the wheel makes it harder and is a not-so-short short cut.
Did any one install a Injen CAI on their auto tranny? Ptuning says its for both transmissions but im not sure. I think it will fit both because injen is bent diffrently than AEM. Correct me if im wrong.
Loose said:
...Injen WILL fit both the ATX and the MTX.
Yep..just as i thought...im glad ive waited for injen. Ill be buying it sometime next month. Ive got the 2.0L and im hopping it will fit.
aem one fits 2.0 but not shure of the injen one...granted the 2.3 draxas header did fit a 2.0
Do you think that i will get the same amount of gains like hp/tq if I install the 2.3l Injen CAI on a 2.0l engine?
should at least see some gains but since nobody (We Know Of) has dynoed this setup on a 2.0...only #s we can give would be speculations at this time...
Right now...
...They are only rated for the 2.3L application. The Injen specifically says "fits all 2.3L applications."
Turbo, I'm unsure if this will fit you car. Before you drop some serious ching you should check it out more.
Tim
If any one has Installed the INJEN CAI PLEEEEEEEEEEEEEEASE post pics of the install more pics the better. I feel like a fat kid with 50 bucks in a candy store with no parental supervision I am undecided and drooling over which one to install. HELP! (omg)
mine is on order for the 2.3L. It should be here in about 5 days if that will help you. I'll take pics and then post them. Hit me up on IM if you have it.
Thanks man I as well as others would appreciate that. You will have to let us know how it comes out. I cant wait to see the pics. Is your 3 an atx?
