Dont know if you guys had seen this. It's a repost from my local forum..
ITB kit for 2.0L FS Engines
AAI Motorsport a.k.a BuddyClub (USA)
introduced direct port injection individual throttle body kit for 1.8L and 2.0L FS series Ford/Mazda engines.
as seen on AAI International Racing team's Ford Tierra RS. (N/A 2.0L FSZE 240hp, FSDE 220hp)
kit includes:
- 4 individual throttle body intake manifold
- manifold gasket and all hardwares (bolts and nuts)
- racing spec fuel rail and 4X440cc. injectors
- TBP sensor adapter
- FRP Air box/surge tank
- full instructions
this kit will work with OEM ECU, after market fuel management recommended.
expected minimum 15 engine hp gains (10-12 whp gain) 5-7 lb/ft turque gain within 3500-5000 rpm
after market exhaust manifold (Header) recommended
Optional Stage 2 kit:
- Stage 1 kit without FRP Surge tank
- Four individual sponge air filters
- ECU harness adapter
- MAP/MAF sensor harness adapter
- Trust/Greddy E-Manage full Engine control unit
- Optimized engine fuel map data CD and base map
expected minimum 25-30 engine hp gains with proper fuel map tuning, the base map works with most applications and will provide 20+ hp gain minimum.
MSRP:
Stage 1 $1595/(1295 USD)
Stage 2 $2295/(1795 USD)
expected labor time: 10 hour for stage 1, 15 hour + for stage 2
Optional high compression pistons, head gaskets and High cams are also available
Stage 2 shown with metal mesh filter and high pressure fuel lines
