BOOST CUT IS FUEL CUT!!!!!!! THERE IS NO DIFFERENCE!!!!!! The map clamp just pushes it back, that's it. The "boost cut" is really a fuel cut due to the ecu demanding more fuel than the fuel system can handle at "x"psi. Why do you think the clamp has to be adjusted with temp. and mods? CP-E even says it themselves that you'll have to lower the voltage on the map clamp if you add more mods or the temps go down more. In open loop, this "can" be dangerous because the ecu goes into speed-density calculations, where it NEEDS to know the map. Luckily with these cars, the turbo is pretty well maxed out, so the density goes down the higher you raise boost over it's efficiency range. That means your motor won't blow when you're telling the ecu to adjust based on lower manifold pressures. Also why people have been blowing motors with bigger turbos and a map clamp. The ecu sees lower pressure and dumps less fuel, lean out, kaboom. With the stock turbo, the extra boost is so damned hot, the density is down enough for it to still be a safe mixture.
If my map sensor was messed up, I would get a code and the car probably would not run right in wot, if at all.
The cdfp IS NOT MAXED OUT!!! IT CAN ONLY DEAL WITH WHAT IT IS GIVEN!!! A high pressure pump AMPLIFIES it's supply. PERIOD! It's the laws of fluid dynamics, and Mazda didn't change that. If you feed it more, it pushes more (up to a certain point). The stock cdfp can handle more than the stock itfp is giving it, and my results are direct proof of that. The upgraded ones can handle it better which is why they have good results too.
The only time the extra fuel is sent back to the tank is when the rail pressure regulator is open (99.9% of the time). Under wot, the rpr slowly closes toward high rpm. When it's closed, maximum potential of the system is reached, and full flow is allowed. With a stock fuel system, the injectors draw the rail pressure (with maximized supply from the pump system) down to a point where the ecu deems it unsafe, resulting in fuel cut. With an upgraded fuel system, the maximized supply is greater, resulting in longer lasting rail pressure (no fuel cut). That's all. Nothing crazy. I'm not claiming to be any faster than before, other than not having fuel cut.
The in line pump has been brought up in the other forum several times, and you still have to get into the tank so you can make a clean penetration for the return. That and you're drawing even more voltage than before (twice or more actually), and you have to work it into the hard-lines that mazda was kind enough to give us.
