ignition coil connector problem
orange pro
mazda protege mazdaspeed
Wats up guys I have a problem here. So mazda doesn't have the best wiring and so my connector to the coil pack broke off... I decided to hit up a local yard and cut a connector off another Pro. My car is a speed but connectors look the same... Wat i'm getting at is before I sauder the wires together I checked to make sure it worked and it didn't. I had rigged it without the connector and it worked same wiring going the same way so idk... Any one else had this problem
Are you talking about soldering your spark plug wires? That sounds like a bad idea. A new set of wires can be found for under $30 if you get the cheaper brands (which I'm sure is better than a soldered set). A coil pack is ~$20 too if that's what's broken
You might want to check the plug itself for corrosion or maybe dirt. That would be my best advise. Also, how long are the pieces of wire you brought back from the junkyard. You may want to inspect the wires for parts that may be shortened (Cuts).
