I had my timing belt, water pump, and associated accessory belts and gaskets changed last Friday by a local independent mechanic who has a good reputation.
After picking the car up I drove to the post office (~ 1 mile away) and noticed while sitting at a red light it seemed a little rougher than before. The needle dose not jump around, there is no unusual noise . . . it just seems to "buck" a little harder every couple seconds when sitting still ad idle. There is no hesitation when dipping into the throttle, and the car feels otherwise the same as before when driving around.
I stopped back by the shop, the mechanic took a quick peek around for loose vacuum lines or sensors but couldn't find any. He recommended driving it a bit over the weekend as I normally would to allow the computer to go through it's readjustment process (the battery was disconnected during the repair) to see if it went away.
Welp, I went through about half a tank of gas this weekend and still think it idles a bit rougher than before. I can't tell if it was there before and I never noticed it, but I'm usually very observant about things like that.
What could cause something like this that may have come up during a timing belt installation? What if the timing belt was installed one tooth off?
