Yep, I run NGK ZFR7F's gapped at .030" but then again my setup is different from most P5 owners.
Technically my plugs are two steps colder than stock N/A Protege plugs (and are extended reach). I run mine one step colder than stock MSP plugs because I run 9+ psi daily. Also, the MSP recommended gap is .028 to .032Do you run the colder plugs cause you're boosted? I only gapped mine at .043, why exactly do you gap yours lower?
