HENRYMP5 said:The car boost guage is reading 23 vac but when rev up it doesn't go over 0 lb of boost could it be due to the leakin the BOV.
It should not while you are sitting still. The car is not under any load.
HENRYMP5 said:At idle the boost guage is reading 23 vac , When reved up it would only go up to 0 on the guage maybe I'm not reving it up enough to get boost or that leak in the BOV is screwing it up.
svxin said:yup thats how mine is hooked up yellow to ecu and blue to o2 sensor try that. that might fix the stalling and the black smoke and so on
How far is it from the turbo now? Is it running better? If you run it to far you will have idle issuesSo basically the MAF and filter are pointing toward the ground right below the intercooler pipe. I will go out and take a pic.
GOTZOOM? said:
