I ran the 1\8th of a mile on 6psi
My best time
Reaction------------.623
60ft.-----------------2.319
330ft.----------------6.499
ET@594ft.----------8.729
1\8th ET------------9.380
1\8th MPH----------69.10
2nd best
Reaction------------.622
60ft------------------2.351
330ft----------------6.520
ET@594ft-----------8.753
1\8th ET-------------9.401
1\8thMPH-----------69.45
3rd best
Reaction-----------.962
60ft-----------------2.306
330ft.---------------6.536
ET@594ft-----------8.763
1\8th ET-----------9.411
1\8thMPH-----------69.46
Hopefully I will run better next month, after I get my emanage on. I came in 4th in the import branch. I know that 1st went to a 96 Supra TT he ran a 7.10 1\8th, and second went to a WRX 7.41 1\8th. I hope to get down into the 8s next time. I am still boost creeping and I think that the problem is the BOV. I need to put some washers in it for space. I think it is opening when I am going into boost. Let meknow what you guys think.(bluemp3) Represting the MP's(guns)
good job bro!
what is this in relation to 1/4 mile times?
What does it translate to?
Your reaction and 60ft times look consistent!
a 9.3 1/8th mile will translate into a low 15 to mid 14 1/4 mile time. I'm running a 9.5 in the 1/8th NA now and my quater time best is right at 14.8 and my dyno number have changed as well with the addition of the headers, P&P, and a 3 angle valve job. I suspect i'm up close or above the 150 whp mark now. All that is left is the underdrive pullys then start to work on the motor torquing too much.
Thats really good CHDesign, when I ran mine with just an intake I was running a 10.5, and a 10.2, with a reaction time of 1.6. I think I figured the light out now though. Yuo know that you are running with a friend of mine that owns a VW 1.8T, he is running 15psi. He runs a 14.6-14.8. Also I was wondering if I went water injection I could run 10psi and be safe right? Wouldn't it be almost like running race gas. Good job CH. Hey spooling have you taken yours to the track? I bet you would be in the mid 8's if you got a good launch. I am shooting for the 8's after I get the emanage and do some tunning.
