With the SS AFC your alowed to
* Eliminates hesitation and stumble under acceleration
* Can control larger fuel injectors
* Easy and clean installation
* Internal MAP sensor for smoother and more precise tuning up to 16 PSI!
* Records data logs with wideband readings to your computer for offline tuning
* PC tunable by both the end user and a shop
I don't know to much about the apexi safc II only that it Modifies air-flow meter signal (pressure signal in some vehicles) to optimize fuel-air ratio; Vacuum Fluorescent Display (VFD). Also the S-AFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %.
