I need intructions for joep's FCD
^tyrant^
does anyone that has instructions for Joep's FCD have a scanner and could post them, i got it from a friend with no instructions or paper work
1) Use a vacume line and tee to tap into a boost source (another vacume line coming off the intake manifold)
2) Tap one wire to the black/green wire on the MAF sensor plug (there should be three wires on the plug, it's the middle one)
3) Ground the other wire
4) Be careful :)
adding to that to adjust when the fcd kicks in turn the hex screw. I believe in makes it kick in sooner, and loosening the screw makes it kick in later...
