- -- 03 P5 / 23 CX-5 --
Here, don't forget this part........
Directions: Set the spark plug gap to 0.025 for best results. Or close your factory gap by .010. Replace cables if older than ten years. With a tighter gap, voltage is less but amperage is much greater. Amps mean HEAT and that is what fires the air-fuel mixture, not voltage. It is okay to use NGK Standard or Bosch Super spark plugs as they have the proper resistance levels. We avoid platinum and iridium plugs because people tell us their cars do not run as well.
