ok so im definetly a newb when it comes to sizes and all of those sorts...
so im thinking of buying rims either 18.7.5 or 18.8s... im most likely going to slap on some 225/40/18 tires... i am also on cobb lowering springs... basically im an not sure at all how the offset works and how i would know that i will not rub...
im thinking about the Rota P45F 18" x 8.0" rims they have a 48et offset and 21lb from **********
or the ROTA Wheels Subzero 18"x7.5" rims they have a 48et offset and are 21.5lbs from racinglab
also what is our hub bore so i can make sure they also fit the car
the subzeros are 56.1mm will that fit? im not sure what the p45fs are
i searched but couldnt find anything that i could understand... i even tried using the tires/wheels calculators but couldnt figure it out for the life of me
if any one has these rims possible on a sliver ms3 post a pic up (or if you have them on any speed 3 so i can see the actual color of the rim)
thanks in advance for any help
