N NEWBMAZDA Member : MAZDASPEED PROTEGE Jun 30, 2010 #1 My MSP keeps on stalling and it hesitates a lot when i boost. I have been reading around the forums and it seems that my WGA went bad. Any suggestions on what else it can be or it is the WGA. Thanks in advance for the suggestions and comments
S StealthWyvern : 03.5 YLW MSP Jun 30, 2010 #2 have you tested your WGA? Do you have a boost/vac gauge? If so whats your vac at idle with ac off?
N NEWBMAZDA Member : MAZDASPEED PROTEGE Jun 30, 2010 #3 how can i test the WGA? i have to take it out huh?
S shane02pro5 25ish_psi : New Caney TX Jun 30, 2010 #4 Pull off the vac line going to it and blow into it to see if it holds pressure
N NEWBMAZDA Member : MAZDASPEED PROTEGE Jun 30, 2010 #5 well i pulled the line and blew on it but it doesnt seem that it is not holding the pressure
L littlemimus fear the mighty sandvich! : Mazdaspeed protege 2003 Jun 30, 2010 #6 NEWBMAZDA said: well i pulled the line and blew on it but it doesnt seem that it is not holding the pressure Click to expand... we generally dont use double negatives in english lol. now spanish is different but.....jk lol looks like u need a new wastegate mister. unless your double negative sentance confused me
N NEWBMAZDA Member : MAZDASPEED PROTEGE Jun 30, 2010 #7 Sorry about the double negatives I was talking to someone else and I guess I wrote. But either way I blew into the vacumm line of the WGA but I wouldn't get any preassure.
