HU or speakers first??
Ok, well you could bump to an Alpine MRV-T320 (80x2) which is $199 at www.thecarstereo.com. It might give you better SQ, but personally I would stick with MTX because they are such a good deal. A Thunder502 (110x2) is only $189.95 at www.sounddomain.com.
For speakers, you have plenty of options in the $200-250 range.
$219.99 CDT Audio CL-61 www.mmxpress.com
$227.95 MB Quart RCE216 www.mmxpress.com
$229.00 Focal 165A www.acaraudio.com
$199.00 JL Audio VR650-Csi www.acaraudio.com
$189.00 Diamond Audio M361 www.acaraudio.com
etc...
You just gotta find a place to listen to them. I can vouch for the CDTs, JLs and Focals. I never liked the sound of MBQs or Diamonds but to each his own.
etc...
your awesome thanks. ive been to a few stores to look but idk they all tell me it differs from car to car and what not so i am unsure really. i guess i have to continue looking as well as hearing speakers in cars i guess. i mean its different in a store then in a car!
in-car is always gonnabe different than in-store, but if you dislike something aobut a speaker in a store it's likely you'll still dislike it in your car. and vice versa.
First and foremost, Make a WAV disc of a couple of songs of varying styles that you're familiar with and like. Personally I've got some Dave Matthews, Fiona Apple, Aimee Mann, Everlast, Dylan, Nirvana, Damien Rice, NIN, Gravediggaz, etc... The idea is to get good clean recordings with songs you know so you can listen for details. Also get some variety in there as well. Another important thing is to try to use straight non-compressed and uncompressed WAV files. you WILL be able to tell a difference with MP3's even if it's very high bitrate.
Take your new disc, and listen to it alot. everywhere you can on whatever spekaers you can. Listen to whatever you think you can afford, and then some cheaper, and some more expensive. you mightbesuprised, but don't let preconceptions and dollar figures influence your ears. let them sort it out themselves.
Nowthen, as far as other variables, try to keep them minimal.
Try to use similar ifnot the same HU's with all of the settings totally flat, no eq's, no crnakign thebass, no "vocal" "jazz" "powerful" setting, loud off, etc, just striaght, clean signal.
Also, you'll eventually want to amplify, ifnot instantly, so, again try to use the same amp or as close to it as possible. And as far as a sub, I'd generally just not use one, though you may wish to add one in and give everything a go with that to see if extended low-midbass which is possibly unneccessary is influencing your decision.
pro5maniac said:
i say we run this setup on my car...nepoc install day this summer?
Kick me $50 bucks and a 12 pack of Caronoa and we can install it any time you like
(thumb)
(thumb)
sounds like an interesting plan...NOW all i would need is the MONEY for the audio stuff and we should be fine haha. but hopefully i can do this before june 26! ill let you know. and one more thing 1sty can you get discounts on stuff or not really?
BluBoy said:
Hey all. I really hate asking questions klike this since the answer is gonna be a personal prefference for just about everyone. Anyway, here goes....
Just bought my '03 P5 a couple of weeks ago and I just gotta get a different stereo in this thing. The factory stereo just sounds awful in my opinion. I don't go for the boomy bass and all that, I just want something that sounds realistic...good frequency response all around. I can't afford to get both a HU and new speakers right now so I'm thinking about getting a new Alpine unit now and just using my stock speakers until I can afford to get the speakers I want. I'm not sure where the factory stereo is the most lacking(HU or speakers), but it seems to be in dire need of some help in my opinion. So would I be better off to get the HU first, or a new set of good quality speakers first??
I'm thinking I would like one of the new Alpine CDA-9855 units and a set of four MB Quart speakers. Think that would be a good combo? Again, I realize it's a matter of personal taste but I'd like to hear some thoughts and opinions on the combo...good or bad.
Thanks in advance. (thumb)
We are playing with alot of things that will come down to personal taste here so I will try to point them out as we go along on our little adventure.
Problem: First, most people dis-like factory systems for a lack of frequency response in the highs and a distortion of the mids at higher volumes. In other words, they don't get loud enough for the listener before audible distortion, although some peole ignore it and even at max, it just not loud enough. A draw back to replacing the factory speakers is that you are going to LOOSE bass, almost always, especialy with only a headunit powering things. Factory speakers are simply easier to move to aftermaket speakers as they are typicly paper, which is about the lightest material you can use, and actualy, one of the best. Less weight, means less power is required to move the cone.
Solution: This is really 2 issues, 1) the speakers can not sound the way you want and 2) the head unit can not produce the power needed to obtain the desired volume cleanly. New speakers will fix #1, a more powerful head unit or and amplifier will fix #2, although the amp better addresses the problem. Even the best headunits only have 20 watts to give per speaker.
Preference: This is where you specificly come in, take a listen to the system as it is and decide if the highs are exceptable to you, for now atleast. If they are, then get and amp first, or as mentioned, a head unit if you need the features. I find that many people are suprised what a 40x4 amp can do with a stock system, especialy if you add a small 10" subwoofer to that amp. IF you like your music LOUD, an amp is not an option, you need one as you are going to blow speakers without it.
Problem: The place where most people over spend, is the head unit. The place where most people under spend is the amp, bascily because they don't buy one.
Solution: Today, headunits will do most everything except make coffee. They have features that most no one needs or knows how to use. If your looking to spend more then $250 on a head unit then your likely looking at products that will do things you have no use for. The only features most people find usefull are having a dedicated subwoofer output, having built in crossovers, being MP3 capable, and satelite ready. Amps can be had for $100-$200 depending on what you need for channels and crossovers. And and amp will always outperform a head unit.
Preference: The reason most people think that a head unit makes things sound better is because it gives them more control to screw up the singal. This comes in the form of the loudness, bass, treble, eq, and other BS boosting circuits that only increase distortion. For some people that ability to tweek is all they need, but again, if they like it loud, they are going to blow speakers from distortion. Raising the bass doesn't make bass continualy louder. It just makes it louder in relation to everything else, this means that it will distort even earlier then it did before it was turned up. This goes for all boosting circuits.
With this all laid out, I would suggest starting with a small 4 channel amp and a pair of front speakers. Don't overlook coaxles as they are typicly cheaper, easier to install and sound every bit as good as you are looking for. IF you can offord it, get a small sub at this point too. The speakers in the fallowing example should be substituted with the ones you listen to and like.
Examples:
Alpine MRP-F240 (40x4) -$180
JL audio TR570CXI (5x7 coaxle speaker) - $150
- by the way, JL components can be had for $200 at a store, not $250 :p
- they are the same as the infinities in that they are not true componenets as they don't have a crossover
JL audio CS110RG-W0 sub and box - $170
Just add an 8 guage amp wiring kit which are about $20 and your done. No need for a LOC as the alpine amp has one built it. Just run the amp to the front speakers and the sub and power the rear speakers with the deck.
This system is $500 and is all top notch equipment. I used these products as they are the MOST I would spend on a system in your situation. Plus you can do it all in parts or mix it up.
Not really. I don't work for any store right now and even if I did tweeter shut down the ability for people to give discounts, mostly just in car audio though.
The Infinities I was refering to do come with an external crossover, thus making them a steal for $112. I think the model is discontinued so get'em while they last.
http://www.cardomain.com/item/INFREF6800CS
I never recommend coaxials, or to be more specific, anything with a tweeter mounted on a post that sticks out of the center of the driver and doesn't come with a crossover. I have never had good luck with them, they get sloppy at loud levels and never have enough bass or even midbass, the tweeters always sound harsh, etc, etc, etc... but I'm sure the JLs sound better to the ones I have listened to in the past.
There is a good debate over whether to buy a 2 or 4 channel amp. If you buy the 4 channel you can
1) power rear speakers
2) bridge it for more power to the front, or
3) when you get a subwoofer you can bridge just the rear for the sub (making a 3-channel amp).
However,
1) I would never power rear speakers,
2) bridging an amp for front speakers can be confusing to the novice,
3) most 4ch models don't have the same xover for front and rear meaning you have to turn them off, and
4) your options are limited as to which subwoofers you can power off the bridged rear channels.
So I would rather choose an amp that will serve one purpose: sending adequate power to your components. A dedicated class-D amp and sub(s) can be purchased later on when your finances catch up.
well the plan i have is to not spend god like amount of money but to spend a good amount. Preferable i would not like a sub for the time being, i want the trunk space or as much as possible and i know i can go custom but thats a lot of money i would not have to spend right now so if anything ill leave that till later down the road. right now i am looking to getting a good set or speakers for the front doors and a good amp to power them. originally i was going to get a pioneer avic-n1 head unit for the gps function but i might not anymore seeing as how the stock HU is good enough for the task at hand. i dont want to go cheap with what i do because i would rather do things right the first way then not do them at all. i am just looking into options to see what i can do to make a clearer sound all through out the board. I do like loud music but i prefer clarity and good quality over loudness, not everyone has to hear your music. also a side question, so its established that the rear doors do not need upgraded speakers then? what would you two recomend to me seeing everything that i have posted? again thanks for the ideas and i hope to get this stuff done this summer or asap! probably for mid june maybe? who knows?
chuyler1 said:
Oh well, I did say "get'em while they last".
The 6.5"s are still available. You will have to create a 5x7=>6.5 baffle out of MDF to install them though...
http://www.cardomain.com/item/INFREF6000CS
The new model is available in 5x7 but they are $200...
http://www.cardomain.com/item/INFREF6810CS
Aaaight...I found a set of 6800cs's. Just ordered them. $119 total. That will be a starting point. I know I want those, just can't decide yet if I want to go amp or hu next. (confused)
Question....How in the hell do you get to the factory tweeters to replace them...and will the infinity tweets fit nicely in the stock location...without ant modifications??
BluBoy said:
"Sorry, this product is currently NOT available"
Don't look like you can get them any more. (huh)
I just bought the only new one on eBay for 90 plus 20 shipping.
HA HA!
(first) (cheers)
I've never installed the Infinity tweets so I can't comment specifically. However for my Eclipse 3/4" tweeters I did the following...
The sail panel pops right off. It easier to get off once the door panel is off.
The tweeter snaps off from the back.
Because the Eclipse tweeters were so small I was able to stick them into the stock location while still in their housing.
For the Infinities, you may have to remove the plastic housing to get it to fit.
If there is extra space, use a hot glue gun to fill the gap. Hot glue will hold it in place but won't adhere to the plastic very well which will help when you go to remove them later on.
I have the same problem, the stock system just wasn't doing anything for me, and I wanted MP3 capabilities, so I just intalled a new Pioneer DEHP3700mp deck in my P5. The way I see it, I can now blast the Sh!t outta the stock speakers, and when they blow, then I can upgrade. (it also helps that I'm a packrat and I have a set of 5x7s just chillin on a shelf)
the difference was immediate! The sound is louder, clearer, and more controlable. my wife doesn't like bass, I like full sound, and the new HU gives better control of how we want to listen to music, and it plays Mp3 (I have 1 disk with 69 tracks, some are 1 hour+ Dj mix sessions) and it plays burn cds (which the factory unit had a hard time doing)
It was the best thing I've done for my car!
i have never had a problem playing burnt cds on the stock hu as long as i made it like a regular cd i beleive wav files not mp3. but thats just me. i am really thinking of upgrading soon so we shall see how the money issue is. maybe ill just buy a set of good speakers and keep em here and get an amp in a while. but who knows!
side question, would there be any benefit putting the front stock speakers in the rea stock speakers place? are one better then another or no?
one set is no better then the others and the front speakers will not fit in the rear.
good to know...now the speaker hunt for me starts. i think this shall be my next mod in the next couple of weeks. get speakers and an amp! now to find a good amp and speakers!
Well, if you can't afford to get all 4 speakers, why not focus on the front first. those are the speakers that you will hear the most, and those are the ones that you want to be at their best.
[hreadjack] hey where in CT are you from? [/threadjack]
Well piss!! The place I ordered the 6800CS's from sent me an email saying that they just ran out of them. These thing must be getting to be fairly scarce. Had to resort to eBay and ordered a set from there. Saved about 5 bucks and hopefully I won't get fawked over by some goddam thief on ebay. Had fairly good luck on there so far. (shady) Oh yeah, just ordered an Alpine CDA-9831 too. I loved the one we put in my son's car at Xmas. Thought it sounded pretty damn awesome. So I got the same thing for my new 5. Prolly a bunch of s*** I'll never use but it's gotta be better than the wimpy factory HU. I'll prolly get me some nice rear speaks and an amp as soon as I get this other stuff payed off. Thanks for all the suggestions guys!! (thumb) And thanks for making me want to spend more money than I had planned to on a stereo. (rofl)
